just need to know "what to buy & not to buy"
Old 04-08-2015, 08:50 AM
ispryonu's Avatar
Default just need to know "what to buy & not to buy"
I have Nitrous Outlet direct port nitrous kit and also new to nitrous. I just need to know what i need to buy to get this nitrous hooked up and ready to spray.
I have:
Want to spray 150 shot for now but upping it later on
Nitrous Outlet 10lbs bottle
Nitrous Outlet Bottle heater
Nos Bottle opener
Nitrous Outlet Gto switch panel
Blow down tube
Purge
Nos Mini 2-Stage progressive Nitrous Controller
Later on i want to forge my stock ls2 to spray a bigger shot like 250-300 shot. Not punching the motor out or anything just forging. I just need to know what r all the things i need.
Thanks for the help
Old 04-08-2015, 09:06 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
Heater, gauge, and RPM window switch are the first 3 in my book. May also consider a progressor if you think traction will be an issue. A direct port will hit a little softer than a plate/nozzle will.
Thanks,
Garrett
Old 04-08-2015, 09:20 AM
ispryonu's Avatar
Thanks,
Garrett
What progressor u think i should need?
Old 04-08-2015, 09:28 AM
You will need one that will handle some ampload since you are running a direct port. I have been using our Maximizer 4 the last couple years and its a really nice unit. Its got a built in RPM window switch and TPS function, and it can activate off of those, but also wheel speed, boost, or all of those together. It's got a built in AFR correction feature too that hooks up to your wideband.
http://www.nitrousexpress.com/15957-...ontroller.html
Thanks,
Garrett
Old 04-08-2015, 10:54 AM
AJatNitrousOutlet's Avatar
"Nos Mini 2-Stage progressive Nitrous Controller"
That is a progressive controller, so if you have that, you are good to go except for the gauge. The mini is more than capable of doing what you're wanting to do-
Quick Reply: just need to know "what to buy & not to buy"
