nitrous wiring (bmn nitro with zex stand alone DBW TPS)
Old 06-11-2015, 02:37 PM
Fenderplayer's Avatar
Default nitrous wiring (bmn nitro with zex stand alone DBW TPS)
This is my first NAWZ install.... any input on my schematic? I haven't found any documentation with a drive by wire TPS switch with the BMN nitro.
Car is an 05 LS2 goat, btw.
Thanks in advance for the feedback.
Attached Thumbnails nitrous wiring (bmn nitro with zex stand alone DBW TPS)-11393089_10102739780220579_4801655252979809735_n.jpg
Old 06-11-2015, 08:39 PM
sh33p4u's Avatar
What's the other end of the purge switch connected to? I believe it should be ground.
Old 06-11-2015, 09:16 PM
Redline Performance's Avatar
you are correct pin 86 in his drawing should be a ground for the purge relay to work. Also the blue wires on the wot switch should be activating a relay that feeds power to the solenoids and the solenoids should have their own ground. see figure 7 in the link.
http://http://news.compperformance.c...ons/ZEX179.pdf
Quick Reply: nitrous wiring (bmn nitro with zex stand alone DBW TPS)
