Car misses shift points when running Nitrous
Originally Posted by Dave00C5
Has anyone experienced this problem with running nitrous on their car?
Originally Posted by ITSovr4U
what do you mean by shift points? DO YOU MEAN WONT GO INTO GEAR. IF SO i HAD THIS PROBLEM, BUT IT WAS THE CLUTCH. I WONT MENTION ANY NAMES BUT THE PRESSURE PLATE WAS CRACKED IN 4 PLACES......and ready to explode.
Yes sometimes mine would bang the rev limiter on the 2-3 shift when running a big shot. I think it's because the converter is slipping a bit more with the added torque. You could lower the shift point to compensate, or bump the rev limiter, depending on what else you've done to the engine to handle the revs...
Mine did this also. I raised my rev limiter about 400 rpm to compensate. I tried playing with the window switch, but it didn't help much. I did away with the window switch in the end. My tranny has 2000 miles on it so I doubt it is going out.
my A4 T/A did that for a while.. When i sprayed it it would always hit the limiter on the 2-3 shift. just a half quart low on tranny fluid though. once i filled it it shifted fine. i run it on street tires right now and it'll hit the rev limiter if it spins real bad. Good luck.
If it is the 2-3 shift. Most like the tranny is going out.
But if you have a window switch, set it a couple hundred below the shift point.
But it is normal for it to shift a bit late with more power.
End the issue with a late model Tahoe tranny pan, you sending all the fluid to the back of the pan. The tahoe pan is slanted forward..and has a drain plug if you order the right one. This assumes the 2-3 clutches are okay. This also assumes it only happens at WOT from a dead stop or very slow roll.
You can order it from Jay Fischer Pontiac (NJ?). He knows the part # and has fixed the 2-3 bounce many times with this mod. You do have to use the Tahoe filter too though.
Originally Posted by LS1M Author
You don't have a part number for that Tahoe pan, do you?
If it's deeper, don't you need to extend the filter down too?
