Stinger plate ruins another rear bumper!
Had some issues with the progressive last night, At least nothing was hurt but the rear bumper cover! Have everything figured out now so next trip we should make a few fast passes.
We had some throttle linkage issues the round before and it was not leaving at full throttle. Fixing that we were rushed getting it to the lanes and forgot to tighten the front end up for the spray. The car is on a 200 shot, That was 60% of it. I am not sure what deceivingly light is, but the car is under 3k with the driver.
Should just take thr bumper off hahaha. Been thinking about upgrading my intake and running a puck or stinger plate. Either way I go I know I will be happy
Here is the video of wheelie number 2! 200 shot leaving at 30% on a 2.5 second ramp. Going to have to add limiters an skis before the next track outing.
Moderator
I was having the rear unload once the front came up and started to settle (radial, and I know that is not your issue). But I went from a 175 lbs rate 18" long spring with shock at full tight to a 265lb spring at 15". This aloud me to use the shock again for control. Not saying limiters can't/don't work, but I feel we often use too soft/long of a spring as power levels increase. Just a thought.
https://youtu.be/u98h4C_7pTw
Watched all the video from Friday night this morning. It doesn't seem to matter what the progressive is set on if you leave with the kit on 25% we still have to pedal the car to keep the nose down. The funny part is it is a total dog leaving with no nitrous. Time to make some adjustments and try again. I will try and get the videos up today.
Strange singles in the front for now are full tight. We are going to add limiters asap.
Old School Heavy
You may already know or have considered this, but solenoids for the Stinger plate have a very large orifice and the 25% progressive setting on the hit that you have programmed is not 25% of the sized jets you have installed, it is actually 25% of the capability of the solenoid. So, if the solenoid is capable of 500 hp, 25% would be 125 hp on the hit. Even if you only have 125 jets in the plate.
If you already considered this sorry for being redundant. If not, pulling some timing can get you going A to B while you iron out the details.
It is tough to turn down a really big system like The Stinger plate to low HP using a progressive. So, turning down the timing becomes neccessary to limit "the hit".
