Everything finally installed
It wasn't fun and it took me awhile, but Finally got everything installed over the weekend. Here are acouple of photos, plan on going with a 150 shot at first. Thanks again Nitrous Outlet, I'm sure I'll have a few more questions for you coming soon.
My SET UP
Fresh 1998 .10 over Block
Stock Rods/ARP rodbolts
New Cast Pistons
LS6 Intake/PP TB
42lb Injectors
Tick Street Heat cam 231/235 | .625”/.605” | LSA113+3
799 Heads/Pac Springs
Morel 5160 lifter/Trick Flow 7.4 Pushrods
Speed ENG 1 7/8 Headers
Magnaflow CatBack
Racetronix Fuel pump/Hot wire
6-Speed/Spec Stage 2 Clutch.
Nitrous Outlet 78mm Plate Kit w/150 Shot
Founders Suspension/Panhard/LCA/Torque Arm
3:90 Stock 10bolt
Torque thrust 10"/315 Nitto 555r on the rear.
New Cast Pistons
LS6 Intake/PP TB
42lb Injectors
Magnaflow CatBack
3:90 Stock 10bolt
