rpm window switch help!!!
im trying to install the window switch for my nitrous setup on my 99 ss camaro, i was just wondering what wire did u guys tap into for the tach reading. thanks
I ran 11.7@116 on stock motor, 3500 converter, w/100 wet shot.
255/16 Drag radials
Stock exhaust (manifolds,y,etc.) w/cut-out
If you have a similar combo with better traction you should do better.
255/16 Drag radials
