NX jets with Nitrous Outlet plate?
Are plates interchangeable? I bought a nitrous outlet plate off of a member here but the rest of the kit is NX. Will the jetting charts and jet themselves remain the same? Plate in question is a 90mm NO plate using NX jets for a 75 and 100 shot on a 98 Camaro.
If you wanted to use our plate that will not be an issue at all . You can follow our jet chart. You will want to monitor air fuel ratio and you will also want to make sure you are using the correct non projected tip spark plug. I would recommend a NGK BR7EF gapped at .030-.032 when using 93 octane. You will also want to read the spark plugs as well to verify what is actually happening in the combustion chamber. We have under nitrous tech on our website a great write up article on proper plug reading. http://nitroustech.com/spark-plug-specs/ If you have any questions feel free to email me or call me 254-848-4300 EXT 109 Houston
