Would a 50 to 75 hp shot help any?
I was thinking about going with the spray. But I don't want to blow anything or screw something up. My car has only 18950 mile's on it and I don't want to have to replace anything at such low milege. Would a 50 to 75 hp shot help any?
Instead of the window switch that he is talking about you can run an even safer setup with a Ramchargers Timing tuner, it works as a window switch, can pull timing on the spray and has a nitrous delay in it too just in case you don't want to spray right outta the hole for traction. Ramchargers is also having a GP in the GP forum on these timing tuners. It is a very good safety device & with the ability to pull timing you can up your shot fairly safely once you get tired of the 50 or 75 shot. You will get the urge for more Nitrous, I can almost guarantee it.
Also if you are looking for a good cheap dry kit, look at Nitrous Outlet's NX Dry kit, easy to install & works good. We picked up a full second on an 80 shot on a 100k mile car with a pretty worn out A4 with the NX dry kit.
Here is the thread for the GP
https://ls1tech.com/forums/sponsor-sales-specials/183084-ls1-timing-tuner-gp.html
