What else will I need?
I'm installing a NOS5177 kit(100-125 shot) with the mods in sig.
I will actually be installing a G5X2(232/240 .595/.608 112lsa) along with the nitrous. I know I will need the following:
WOT Switch
Window Switch
FPSS
N20 gauge
fuel pressure gauge
Did I miss anything? Will I need bigger injectors or a higher flow fuel pump/
WOT Switch
Window Switch
FPSS
N20 gauge
fuel pressure gauge
i would definitely upgrade the injectors and fuel pump for a dry shot with that size cam. as for the driveshaft, i think your rear (if its a 10 bolt) and your clutch (if its stock) will give out before the DS.
I don't use the fuel pressure safety switch. Add a bottle heater (preferably the pressure activated kind). A 255 or 340 walbro intank with some 30 lb svo's would be a good idea, but will require some tuning.
