purge line question..
hey guys, I bought a used 5177 kit and it has a purge kit also, the purge solenoid has about a 7" piece of hard line coming out of it, the previous owner cut it he said. I was just wondering, what could I connect to this line to route my purge? can I just use rubber hose with clamps, or what? Does it have to be hard line from the solenoid? I work with pnuematics and hydraulics, so I have all sorts of flex-tube and fittings, but no hard line. I could even adapt the solenoid to use the hydraulic tubing from the source, but I figured I would ask first.
If hard line is required, some info about how to accomplish this would be nice!
thanx-William
thanx-William
1 Post
You don't have to use hardlines. I bought the dual purge kit from Dynotune, and they used a t- adapter with 2- 90 degree adapters and a flexible plastic tubing.
So yes.. you can use a plastic type hose.
