how can i test the system when using a window switch..
i just got my NOS Dry kit installed and before i make a wot run id like to test the system to make sure its all working and there at no leaks around the noids or lid.. how can i trigger the system with the car off and the lid removed when i have a MSD window switch installed? is there a way to bypass it without removing it?
I just start the car...arm the system, hold the WOT switch down with my finger...and rev the car just above the rpm required to fire the noids using the TB quadrant. Be sure the lines are not in the air inlet and are secured. If they are just laying free they will wip around. If you want to test the off point...put pills in that are lower rpm...like a 3000 on and a 3400 off. You can then watch it turn on and then off.
