How to mount the bottle in the spare tire well??
Can someone tell me how to mount the bottle in my spare tire well? I just can't see it with the brackets I have. Are there special brackets? And can you fit a 15# bottle back there??
We bent 3/16" X 1" steel bar stock in to triangles about 3/4 the width of the spare tire opening. Put normal bottle brackets on the bottle and have someone hold the bottle where it fits best. Mark where your triangles need to be and either weld or bolt in. If you bolt in, use backing plates. My 15# bottle w/ opener fits snug. I have foam padding between the bottom of the bottle and the inside of the rear panel. Piece of cake. I could get dimensions for you, but it wouldn't be until the weekend.
Also, used a 6 wire connector as a quick disconnect for the heater, and opener. Just unplug it, 2 bolts and the bottle is out in tact.
Good luck.
Good luck.
10 Second Club + 14 Second Truck Club
Good luck.
Good luck.
A 15 pounder fits just fine in there. We welded 2 straps across the area and mounted it. Even with an NX bottle blanket (very thick) I can still put all my interior panels on and you never see the bottle.
