guys with 100-150 shots, what cam are you running?
im interested in seeing some numbers for those of you running aftermarket cams. right now im considering the fms fm7 nitrous cam, but id like to see what others are running before i make my decision.
with all the bolt-ons, stage 1 heads, and a 218/222 .559/.566 115LSA cam (mild) I got 440rwhp/460rwtq on a dynojet with a NOS 150 dry shot. I do go lean for a few rpm like everyone else with a dry kit, thus I got a NX wet kit that I'm putting on once I get my new cam tuned in.
44o w/the 150dry sounds off. It's gotta be a typo.
I'm making more than that w/my stock motor and NX150wet.
I've decided on a TR224/227 for my N2O set-up. Not running it yet though so my vote shouldn't count for much.
224/224 114 cam , Stage 2 heads, 12 bolt, blah blah blah
400 rwhp / 373 rwt (N/A) after 300 miles on rebuilt motor
536 rwhp / 569 rwt (N2O / 125 shot) after 300 miles on rebuilt motor
I have Futral's FM-8 cam, slightly bigger than the FM-7 (225/233). I put dowm 513rwhp and 575rwtq on a progressivly controlled 150 shot. That dyno run was with a cold bottle (850 psi).
BTW stock heads, stock bottom end. I went 10.71 @ 128 1.55 60ft.
Allan's cams are great, You cant go wrong with him. Call him and ask which on he recommends. The FM-8 I got dosen't idle bad either similar to a hotcam, I also made 375rwhp 375rwtq on motor.
1 Post
I'll be spraying my 150 shot on the stocker for now..
Still trying to decide what cam I should go with after my first Cali smog has passed..
It'll more than likely be the TSP 231/237
