How to properly purge with no purge valve?
I just got my kit put on today and the guy that installed it said that I have to get rid of the pressure on the lines before letting the car sit or it will affect the selenoids. He told me that since I do not have a purge valve I should turn the bottle off and then activate the N2O it until the car starts to bog down, then shut the arming switch off. He said this will get the excess N2O out of the lines and release the line pressure so the selenoids dont have to work so hard to hold the line pressure. Sound right? Is there any other way to release the line pressure? I trust this guy, I just want to know the tricks of the trade here? Thanks
Cajun
Cajun
If you have a wet kit and your purging the rest out of the line, remember that you will also be spraying what little fuel is left also, and even with the car shut off it will hold fuel pressure, when you go to restart the car, usualy right away it will blow the entire intake off the car,(nitrous backfire) Just crack the line loose a lil in the back when you shut off the bottle, thats the safest way. Learn from the mistakes of others. You can close the bottle, arm the system and do a short run, youll feel it kick in and then bog cause your only getting fuel. then you know its out for sure. BTW, purge kits are fairly cheap, We constantly have them in stock and most others do to. When your ready give us a call. Without the purge kit it is best to just open the line.
Steve@NitroDaves
Steve@NitroDaves
Originally Posted by Steve@NitroDaves
If you have a wet kit and your purging the rest out of the line, remember that you will also be spraying what little fuel is left also, and even with the car shut off it will hold fuel pressure, when you go to restart the car, usualy right away it will blow the entire intake off the car,(nitrous backfire) I know cause Ive done it before, Just crack the line loose a lil in the back when you shut off the bottle, thats the safest way. Learn from the mistakes of others. You can close the bottle, arm the system and do a short run, youll feel it kick in and then bog cause your only getting fuel. then you know its out for sure. BTW, purge kits are fairly cheap, We constantly have them in stock and most others do to. When your ready give us a call. Without the purge kit it is best to just open the line.
Steve@NitroDaves
Steve@NitroDaves
