Safe timing with NOS 01577
12 Second Truck Club
From the FAQ that is stickied at the top of the forum:
Q: What are some of the general rules for even higher HP gains?
A: Generally, forged aluminum pistons are one of best modifications you can make. Retard ignition timing by 4-8 degrees (1 to 1-1/2 degrees timing retard per 50 HP gain). In many cases a higher flowing fuel pump may be necessary. Higher octane (100+) racing type fuel may be required as well as spark plugs 1 to 2 heat ranges colder than normal with gaps closed to .025"-.030". For gains over 250 HP, other important modifications could be necessary in addition to those mentioned above. These special modifications may include a forged crankshaft, a high quality race type connecting rods, a high output fuel pump dedicated to feeding the additional fuel demands of the nitrous system, and a racing fuel with high specific gravity and an octane rating of 110 or more.
11 & 7 Second Clubs
You should call an expert such as Futral, Thunder, APE, W2W, HPE, NOS, NX ,etc. and ask them, rather than take a poll on a web site. JMO.
Originally Posted by Z284U2TRY
Are you saying on the spray your timing is 28? Mine usually runs about that n/a and when I hit the spray I end up around 24. dry shot
Thanks
