Help W/ Spark Plugs And Stock#s
I'm sure it has been asked before and yes I have used the search button. I will be have my new motor installed soon and need some plug advice, The biggest thing is the car is a daily driver, here is my set up:
383 ls1 w/weisco pistons 10.75:1 compression, Patriot stage 2 ls6 heads 2.055 int/ 1.60 ext, 224/228 581/588 114 cam other mods in sig.I will be running between 150-250 shot w/ my tnt f2 kit w/ all safety goodies. HPE told me to run a TR7 or TR8, what do you nitrous experts recommend?I was looking at the TR7 but there seems to be a whole lot of different #s What # plugs do I need and where can I get them?I tried Autozone and Kragen's w/ no luck.So anyone with part# or stock # that would help me a TON!
Anyways...
R5671A-8's are the 8's
R5671A-7's are the 7's.
I run these because they have a gasket and it pulls the plug out of the chamber to reduce heat that much more. I usually get mine from Oreily's.
Mike
Mike
Mike
