Safe psi
Old 06-25-2005, 08:00 PM
ws6nick's Avatar
Default Safe psi
I live here in Central Texas and with a black car it gets pretty hot. Do I need to worry about a leak due to high psi, also what is a safe psi before something leaks? An would there be a big difference between the trunk and inside the car temps.
thanks
Old 06-27-2005, 11:29 PM
Nitro Dave's Nitrous Outlet's Avatar
I do not suggest leaving the bottle in the car during the heat of the day.The saftey disk is desighned to pop at 3000 psi.Make sure you do not spray above 1050psi.
Dave
