What injectors should I go with?
Old 06-26-2005, 10:04 PM
DragonRace's Avatar
Default What injectors should I go with?
I have a 99 Corvette that I am putting a 75 shot dry. I already have heads and cam. The heads are a stage 4 port and polish but stock valves and the cam is the Texas Speed MS3. What size injectors shoul I go with? Thanks
Old 06-27-2005, 04:09 AM
v8-7's Avatar
im running 30# in my car for a 100 or 150 dry. Gotta figure out what your injector duty cycle is when you spray and what the a/f is when you spray. You dont want to be any higher than 85% duty cycle in the peak RPM range. Otherwise go bigger. More than 85% is fine, but is stressful for the injectors. someone i know -looks down on the ground and kicks a pebble-- has ran their injectors at 100% maxxed on my turbo car. and survived a few battles. Dont try and follow that "persons" foot steps, haha.
PS from what ive read, most ran stock injectors with the ammount you are spraying...
Old 06-27-2005, 11:16 AM
Robert56's Avatar
Projected HP x .5 / 6.4 = min injector size
