What should my car run on a 150 shot?
Old 08-03-2005, 09:16 PM
02Z28's Avatar
Default What should my car run on a 150 shot?
I have a 02 Z28 with all the bolt ons plus a FM13 cam. Best run so far was a 12.33 in 98 degree weather. Just installed a TNT kit with all of the goodies plus a fuel pump. What should my car run? Its a M6 and I wont be spraying in first.
Old 08-03-2005, 10:31 PM
slow trap's Avatar
not spraying in first i'll say 11.30s to 11.50s with 10-12 mph increase.
Old 08-04-2005, 01:51 AM
Robert56's Avatar
About right, or better. There are so many variables to consider.
Robert
Old 08-04-2005, 01:56 PM
jwitt2's Avatar
i bet when the temp drops to below 60 you might see 11 flat or 10.90's
depending on your 60ft.
Old 08-05-2005, 10:25 AM
02Z28's Avatar
Thats what I'm thinking. I know the car has a high 11 all motor, now if I could get some traction
Old 08-05-2005, 10:58 AM
jwitt2's Avatar
what tires you running on???
recent 60 ft's?
Old 08-05-2005, 11:04 AM
2000blackSS's Avatar
get bfg drag radials have the juice hit a 3k lauch at about 4600-4700rpm slip dump....i cut a 1.75 doin that on a stock clutch if u slip dump properly u will not shock the rear everything will be fine
Old 08-05-2005, 07:05 PM
02Z28's Avatar
Have nittos right now best 60 was a 1.94 most of the time they are low 2s. Thinking about get some MT's and I might be ordering a 9" pretty soon which should help those 60 fts. Best run was a 12.33 at 115mph!
Old 08-05-2005, 07:27 PM
GM Muscle's Avatar
Get that 60' down to about 1.50-1.60 range and the car should consistantly lay down high 10s. Just dicking around I would expect low 11s at about 125mph.
Old 08-06-2005, 02:03 PM
02Z28's Avatar
They are repaving the track next week so that might help a little too!
