860 Bottle Heater Wiring?
I have one question about the black wire that comes off the relay it says to attach the black wire to 20A fused 12V+ supply. Which should be taken directly from the battery with a in-line fuse. So do I run the black wire to the positive side of the battery and have a in-line fuse installed?
Yes, that is correct. The black wire from the relay harness needs 12v+ supply from the battery. You can use the supplied red wire to extend it up to the battery, and a 20A fuse is always a good idea.
Goodluck with the rest of your install!
