wet or dry kit
You could do a dry direct port if you're using an aftermarket stand alone engine management system. If you're keeping the stock PCM you could do a wet DP with a stand alone fuel system or even a dual nozzle wet kit at the power level you're looking to spray.
Matt
Matt
Actually Nitrous expresses single nozzle kits will produce up to 250 rear wheel HP.If you wanted to keep it simple you could use NXs single nozzle,Maff kit or even the dual nozzle kit we have on special.If you think you may be wanting to spray more in the future check out some of the directports we offer.We are well known for having the best directport setups.Also check out our stand alone fuel systems.They are the best on the market.
Dave
Dave
