Can someone look at my wiring and confirm?
I am trying to wire a 2 stage n2o setup. The first stage will be a dry shot controlled by an MSD digital window switch. The second, a wet controlled by a Ramchargers Timing Tuner. I want the stages to also be able to run independant of each other. Please check the attached wiring diagram to see if my wiring is set up right? Thanks an advance for any help.
