stall
Restricted User
Yep, go more than that and you better be able to spin it tight, as nitrous pushes past the normal TC rules. My old 3000 Yank used to flash at 3400 and shifted the same. I currently run a turbo spec'd Fuddle 3800 2.5str, of which I havent sprayed and may not since I am selling it. But the new one will be a 4000 2.4 or 2.5 STR and I am sure it will see 4600 or so out of the hole with 200 shots.
unless you are runing slicks, spraying out of the hole isnt going to work very well. I love my 3800 Vig, but i cant spray as soon as i would like. Getting slicks and QA1's so i will let you know how that works!(If i dont shatter my 10 bolt 1st!)
