Sources of switched power
I hooking up a bottle pressure gauge and need to hook up a 12V switched power lead. I've done this already for a window switch and master switch console (both to the fuse box). My question is where else do you guys hook into. Right now the window switch and switch console both go into the same lead. Can I do the same with the pressure gauge? Is it ok to hook two or three devices together into the same power out in the fuse box or am I looking for trouble. They're fused btw.
