Z06 needs nitrous help
I'm thinking of a nitrous system for my Z06.I'm in the low 11's na but would like a 75-100 shot to dip in the 10's.which is better wet or dry for this and what should I use for a trigger(tps? or wot?) need a window switch?and are 4.10's(m12) to much for the spray?
Steve,
Your ZO6 does not have a throttle cable so you have two choices.A TPS or mounting a micro switch under the throttle pidal.I prefer the TPS but only because I hate crawling under the dash.LOL. Both will work
I would look at NXs new maff kit for the ZO6.It comes with a TPS and a pre built harness.So install should be fast and easy.Its a wet sytem. I still suggest a window switch for safety. Is your car a auto or six speed.If its a auto 410s may be a bit much gear.If its a six speed you should be fine but may need a taller tire.
Dave
Dave
