Need help finding power supplies..
Old 09-30-2005, 04:54 PM
Okie02's Avatar
Default Need help finding power supplies..
ok i had a few quick questions..i want to run all my accessories off the fuse panel that is located in the cab..the one on the drivers side on the side of the dash..which fuses are a switched 12 volt..obviously the radio acc. is i think..what else is? and also i have a nx heater and i was wanderin if i could run the black wire from the relay to the cig. lighter fuse? its constant correct?
quick replies would be appreciated as im in the middle of doin this right now..thanks alot
Old 09-30-2005, 05:02 PM
Phoenix 5.7's Avatar
do you know how much power/current all of your accessories are goin to draw? one thing you could do is use a relay and get the signal for the relay from the radio/acc place in the fuse panel. the cig lighter is a constant power. also the TCS/ASR switch has a switched power that would work for a relay. since you are in the fuse panel, the batt place would work for a cosntant power for the relay
Old 09-30-2005, 05:32 PM
iamsickofitall's Avatar
the IGN slot is a switched 12 volt - i use that for mine
i believe the BAT slot is constant
no need to try to sandwich other connectors plus the fuse in the fuse slot
Old 09-30-2005, 05:34 PM
gollum's Avatar
Old 09-30-2005, 09:58 PM
Okie02's Avatar
What do you mean the ign slot? you mean where the ignition fuse is? and also what is the BAT slot?...and what do you mean by "i use that for mine"..you use what? all your accessories? sorry for all the stupid questions..
