afr and timing
afr and timing
yeah i just got my car dynoed and it makes 395hp and 370tq.my afr is 13 straight across. i want to put a hundred shot on do i need to take some timing out or can i just leave it like it is. and will i need to upgrade the fuel system
If they added any timing in the tune I would suggest retarding a few degrees. Since you have a cam I'd also run an upgraded fuel pump, like the Racetronix plug and play system.
Matt
Matt
