02 banks wont go higher?
Old 10-08-2005, 10:53 AM
2001z's Avatar
Default 02 banks wont go higher?
I am trying to get my o2 banks set to 900 mv and for some reason it wont go any higher that mid to high 800s is this becouse of my o2 simulators ? im using the live time data in the predator and changing the power enrichment to acchieve 900 mv on the 1st and third banks for fuel. does anyone know what the deal is i tried going up as high as 1.970% which it didnt increase at all. i had no trouble setting my timing just my o2 banks . I know i need to get a tune but i just want to da a safe tune with the predator for the time being . Or should i just put the custom tune in that they sent me and go with that ?
Old 10-08-2005, 01:15 PM
Restricted User
CAT3's Avatar
Maybe your out of injector?
Old 10-08-2005, 02:54 PM
2001z's Avatar
ya maybe i just cant see why it wont change on the real time data and its not consistant on every run at wot. Does anyone know if you put o2 simulators on that you have a problem reading on the first and third banks?
Old 10-08-2005, 03:29 PM
DevonsZ's Avatar
Im pretty sure mine will go up to 900+. Ill check in a little bit and make sure though.
Old 10-08-2005, 06:59 PM
2001z's Avatar
do you have o2 simulators i heard the o2s are a little wacky.
Old 10-08-2005, 07:05 PM
DevonsZ's Avatar
Yes, I do have 02 sims and under wot line #1 was around 920, line #3 was around 870.
