Nitrous/injector?
Nitrous/injector?
If I'm running a set of LTs,a lunati cam 221/211 .558/.558 114 lsa, stock heads and intake. I want around a 100 shot of nitrous can i go with a dry kit or is that pushing the fuel system to the limit its a 98 so it has 28lbs injectors, if so should i get bigger injectors/fuel pump or a wet kit?
I would definitely suggest upgrading the fuel pump, since you already have a cam and most of the bolt ons. If at all possible log you injector duty cycle. With a 100 shot you'll be close to or possibly past 80%.
Matt
Matt
