am i ready to spray
am i ready to spray
ok i just installed my custom nx dry kit. it uses nx solenoid and bottle and lines but is a dry kit. i have 900 psi in bottle and just installed ngk tr6's and am going to install a bnm window switch asap. is it ok to spray 75-100 shot after this or is it really necesary to go see what my af ratio is on the dyno. thanks all suggestions are appreciated. i want to try it NOW but want to be as safe as possible.
LS1TECH Sponsor
We sell a very affordable a/f gauge that can help you out.....
www.dynotunenitrous.com
we have widebands for $279!!!! 75hp shot is not a bunch. You will hardly feel it. Floor it and manually hit the arming switch so you can feel the change. If you dont feel an increase in power after a few seconds STOP! If you feel like its pulling a bit hard then its probably working ok. Always best to have a gauge! once you use 100hp youll want more so get the gauge now so you dont need to guess where the a/f is down the road .
Cheers
Dan
Cheers
Dan
