04 GTO Nitrous Question
I am NOT experienced in the LSX Motors. I am wanting to run a 150 Wet Shot of nitrous on the stock engine. I need you all to help me figure out which system and is a 150 shot safe for years and years(so to speak) if it is tuned?
Thanks for the advice
Blake
Blake
There is alot of good systems out there to choose from. A friend of mine runs a 150 NX kit on his 04 with a timing tuner. He juices the living hell out of it in the summer time and never had a problem.
Check out Nitro Daves, He has a dual nozzle NX kit that is on special right now. Here is the thread.
https://ls1tech.com/forums/nitrous-oxide/416742-christmas-specials.html
There are many ways you can go for a system. You can go with a simple NX single nozzle or a more custome looking system such as our plate system or NX maff kit.
For some real good information pick up this months GM HIghtech.....
The key to having a safe system is buying a system wiyth good quality parts and the needed nitrous accessories..
I suggest deciding which system fits your needs best.
Wet or Dry?
Single Nozzle,Maff,or plate.
Then get a window switch,fuel pressure safety switch,nitrous pressure gauge,bottle heater and purge..
Check out the link with our christmas specials.If you do not see something that works for you let me know. Also if you need some one on one help to help you decide what works best for you send me a pm.
Thanks
Dave
Wet or Dry?
Thanks
Dave
