Would i need to upgrade fuel injectors if...
i go to a 175-200 shot on my fully built forged 355?
also should i worry about the rear end on a A4?
tranny is built for 800+ rwhp so no worries there...
and how much timing would i need to pull on those?
It depends. Assuming you're talking about a dry shot if you're talking about injectors, so in that case, most likley (depends what size you have). If you're planning wet or DP, then no, just need to make sure you've got enough pump. Rear end is always a weak point in these cars, I wouldn't worry on the street, but spraying out of the hole on slicks at the track I bet it won't live too long. Probably pull around 6 deg of timing, need to due some tuning to know for sure.
i already have the kit and its wet.. been on the car for a while..
im just uping the shot now, since i have a motor that can handle it, unlike my other one i blew up on n20.
i do have a bigger fuel pump 255....
