? for those running a fuel pressure gauge with a wet shot
I want to run an autometer fuel pressure gauge but my nitrous fuel lines are hooked up to the shrader valve where the fuel pressure sending unit goes. Does anyone know where I can get an adapter or an inline sending unit of some sort?
You need a -4an manifold/gauge adapter. Dynotune has some nice ones, http://www.dynotunenitrous.com/store...?idcategory=42 .
will this fitting work without the nitrous, I just need to install the fp sending unit, does the front of the fitting have a shrader valve in it or is it open for wet system hook up?
Yes, it'll work but you'll need an AN cap for the end to cap it off. We have a few styles to choose from, but I prefer the swivel adapters as you can move the NPT port around after it's been tightened. I'm not sure if the AN caps are on our site or not, but they are around $5.
http://www.harrisspeedworks.com/shop/home.php?cat=348
Thanks,
Matt
Thanks,
Matt
