Hiding nitrous
Old 04-30-2006, 09:00 AM
ws6runsTHISshow1288's Avatar
Default Hiding nitrous
I was wondering if there is any way to hook up the nitrou system and be able to hide it completely. If someone looked at your motor, I would want them to see nothing at all. Had anyone done this? I'm thinking you could just have the purge shooting down maybe
Old 04-30-2006, 09:03 AM
blacktransam's Avatar
yes but good luck getting any one to really post a pic or tell you how..
do a search for nitro daves money maker.. you;ll get the idea
Mike
Old 04-30-2006, 10:48 PM
BottleOrBoost's Avatar
Mount the fogger low, on the underside in front of the throttle body, cover the feed lines in black split tubing, and mount your solenoids inside your airbox...
Old 04-30-2006, 11:12 PM
zspot98's Avatar
Keep your hood closed? Or get w/ Nitro Dave and I'm sure he'll be happy to help you out.
Old 05-01-2006, 06:48 AM
lol thanks
Old 05-01-2006, 09:18 AM
02NBMFormula's Avatar
if a person knows what to look for, they can usually find it
Old 05-01-2006, 09:26 AM
Import Patrol
CrawlinWS6's Avatar
And letting the car purge, under the car is not a god idea.
First off, It's nice seeing the purge, so when you kow the air is out of the lines.
Second, the sound of someone purging can be heard from a distance.
Old 05-01-2006, 10:25 AM
fstphx's Avatar
no need to really purge- so you dont have the best gas off the line-
sounds like a great way to launch to me-
just spray during a quick burnout while heating your tires-
Dry kits are easiest to hide-
do a search lots of info and pics available-
Old 05-01-2006, 12:11 PM
yeah i have a wet system. I know the it is not good to purge under the car but I want it to be unnoticable.
Old 05-01-2006, 12:23 PM
Reject's Avatar
lol purge inside the cabin??? lol
Old 05-01-2006, 12:34 PM
00turboT/A's Avatar
[QUOTE=fstphx]no need to really purge- so you dont have the best gas off the line-
QUOTE]
Not purging leads to fuel puddling up because there is no nitrous to atomize and which leads to blowing the intakes and air lids off the cars.
Old 05-01-2006, 01:06 PM
daryl2cb@yahoo.com's Avatar
that and hitting below 3000 rpm, not enough air velocity to completley pull the extra fuel threw the intake.
Old 05-01-2006, 01:42 PM
chris.shea's Avatar
a dry kit would be easiest to hide. getting fuel for a wet kit is tricky and if you ad the safety option(fpss) someone will spot it. i like the fact that the corvettes have the fuel rail covers but guys still asked me to see under them before i even had nitrous... i tell them no and to either put up or shut up. silly ricers take 30+ minutes to set up a race...
Old 05-01-2006, 02:46 PM
STRIPSTAR's Avatar
Harris Speed Works has some sweet hidden setups.
Old 05-01-2006, 03:03 PM
^^ thanks. I allready have my nitrous kit though. do they offer things that will hide the kit you have? Or do they offer completely new kits that you can install?.. I am thinking about mounting my solenoids somewhere low maybe behind a fender ( risky if an accident though), putting the purge out a wheel well so you cant see the purge solenoid, and a far as the wiring, ill cover it in black tape and write things on it that would say compression hose or something random so nobody would know what it means. I would tuck it all away. the hard thing is going to be the fuel line from the fuel rail though. Any 1/2 way smart guy can pick out that line. I will put the purge/ arming switch under my seat. I dont know how I am going to hide the WOT throttle sensor though ( the thing the throttle hits when full open). ? any ideas of how to cover that up?
Old 05-01-2006, 05:31 PM
fstphx's Avatar
[QUOTE=00TurboT/A]
QUOTE]
thats a negative ghostrider-
first off- dry kit no issues with that-
second-wet- still dont belive it-
you are gonna run rich for a fraction of a second but you are also at wide open throttle- not gonna puddle-
as far as the WOT switch- mount it to the pedal- nobody is gonna find it there-
Old 05-01-2006, 07:22 PM
[QUOTE=fstphx]
^ ghetto though... dont ya think? ...
Old 05-01-2006, 08:23 PM
98redorangeta's Avatar
As for the wires just buy some trans cooler line and run them in side that. With a wet kit though hidding the nozzel good luck any one is going to be able to find it if its any where in the intake tract besides in the air box itself and then you cant run a maf the fuel will mess it up.
Old 05-01-2006, 08:31 PM
TMoNeE's Avatar
[QUOTE=fstphx]
You're right, purge is just all marketing and show.
Old 05-02-2006, 12:48 AM
TwoFast4Lv's Avatar
Not always true
Quick Reply: Hiding nitrous
