I found the car... how much should i put on it? ( spray)
I found my car today. It is a 1999 t/a. It isnt the WS6 but it is the trim before that. I think it is the motor w/ 305? How much wet kit nitrous is reccomended for that car that i can use alot and run safely?
Restricted User
All models are the same. All trims levels are the same. The all use the same internals and the little "xxx" badge is thrown out the window as soon as the first non-stock part goes on. Other then that look thru search results.
GRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
https://ls1tech.com/forums/showthrea...o_threadsearch
How to keep an idiot busy for hours..
Also do a search, this is another one of the beaten down topics here.
