nos dry kit
nos dry kit
i am hooking up a nos dry kit. where exactly is the fuel vacum line to hook the fuel thing up to? ill go take pics if somebody doesnt have any but could point it out. thanks alot guys....
LS1TECH Sponsor
Are you putting this on the 99 SS? The N2O regulator isn't used with an LS1.
If its going on a LT1 or a TPI you will run a vacuum line from the N2O reg. to the side of the bypass T and from the other side of the T to the FPR. Depending on the age of the kit the T will have a jet or it could have a small .059 hole in the bottom leg, this will go to the factory vacuum line that was hooked up to the FPR.
Kyle
Kyle
thanks for the help. ive had to do this to a few cars of mine and was going to do this to my ss but wanted to ask first. ill pick up a window switch and some other safety things to be safe.....
