Injector Size for dry shot
Ok, i am running everything in my sig. and 30#svo Injectors. when i record data with the datamaster the injector duty cycle is around 77 .. What size injectors would i need to run like a 150 dry shot? I was thinking 36# injectors would be ok? Is there a formula to figure this out? Thansk for the help in advance!
http://www.rceng.com/technical.htm
You should be ok with some SVO 42lb greentops.They are cheap to buy too.
