Set up for WOT?
Set up for WOT?
the kit that i have dosent come with a WOT switch. And i really want one. so im buyin one from jegs. First question, the WOT switch that you get a jegs dosent come with any wires, so were do i get the wires to hook it up to my 12 volt source. Second question, will it interefer with the window switch i have? Thanks
any 16 gauge wire will do the job. just connect the positive wires from the solinoids and run one wire off of them to the WOT switch, then run a second wire from the WOT switch to your toggle switch. and no it will not affect your window switch.
