90mm plate and stand alone questions
Just wondering if anyone had any opinions or results from NOS's 90mm plate system they would like to share. I guess this would be considered their LS2 Kit? Planning on running a 150 wet hit which leads me to my next question.
I was planning on using my alky control system as my stand alone. See any problems with this. Would be running C16 in the SA tank. Was thinking about using a second fuel solenoid directly before the main fuel solenoid to act as a purge to rid air out of the fuel line. This air and fuel would just dump back into the SA tank. Any opinions?
Not sure on the equation, but its rated at over 100psi on its 1/4" outlet. This kits only got about 3 hours on it. I may have to use some type of regulator though because it is variable speed and vary touchy to its adjustment.
I agree with Cat 3 but to add to it put a return style regulater to do away with the posibility of a lean spike. No need to run two fuel solenoids.
If you decide to add a dedicated fuel syetm and not make what you have work we stock dedicatd fuel systems and cary the NOS plate kit also.
Dave
Dave
