People who've installed DynoTune Two Stage RPM Window/TPS Switch PLEASE HELP...
I'm installing this on a friend's 2001 SS and have two questions...
Where does the green wire (tach signal input) go (I assume the white wire on the blue side of the ECM) and where does the blue wire (TPS input) go???
The blue wire is so the device can know when the car is at full throttle correct?
Thanks!
Thanks!
Thanks!
Thanks!
Havin' a little problem there Mark? I'm assuming you never finished the install.
