Picture of Nitrous Dave's Mounting Bracket?
Old 06-23-2006, 09:01 PM
Letsndy's Avatar
Default Picture of Nitrous Dave's Mounting Bracket?
Does anyone have a picture of the plate installed in the spare with out the bottle.
i see the on on his website but cant figure out where the bottle brackets screw into.
do you have to make your own holes?
thanks in advance,
Letsndy
Old 06-24-2006, 12:32 AM
Riddlerls1's Avatar
You do have to drill holes in the spare tire well if thats what you mean. The bolts go through your drilled holes and are attached on the other side via nuts and washers.
You do not have to drill any holes in the mounting bracket itself if that is your question.
Old 06-24-2006, 12:45 AM
Unstang's Avatar
I didn't drill any holes, it is sturdy enough without them...
This pic, the bottle is installed, but I think you can see how the brackets go and see that I didn't drill anything.
http://picsorban.com/upload/dsc00458.jpg
Old 06-24-2006, 09:16 AM
spson04's Avatar
no hole required, jus put the bottle in the passenger seat and dont forget buckle it up, its the law
Old 06-25-2006, 07:15 PM
Letsndy's Avatar
thanks, that helped!
Old 07-30-2006, 07:06 PM
blind527's Avatar
Did you mount a flow boff tube? If I get this bracket, will the TNT blow off tube be long enough to go through the bottom of the spare tire area? I'm going to have to drill a hole in the bracket in this case of me putting the blow off tube in.
