Stroker N2O comp ratio
I'm going to order a short block thru a local shop this week, Im looking at a 6.0 iron block .030 and a 4.1" stroke i believe. the only thing I have not decided on is compression ratio. I have done a lot of research, talked to old school racers Etc. And am still having an issue deciding this.
Im will be running a comp cam, .622 lift, 258 int and 270 exh duration. I will also be running a pretty healthy nitrous shot. What are people running for comperssion ratios and nitrous? also on the larger nitrous shots, what timeing advance are you able to run?
