lt1 cold fusion dry kit results
Old 06-29-2006, 12:10 AM
94vette's Avatar
Default lt1 cold fusion dry kit results
just wanted to share my results on my cold fusion dry set-up.
94vette lt1 a4 exhaust and 3.75 gears..pretty stock
nitrous stuff: window switch ,fuel pressure switch, lean alert wideband controller and fuel pump
first run 75 jets a/f 12.1
2nd run 100 jet a/f 12.3
3rd run 125 jet a/f 12.9 ..the max i would go
results are that the pcm can compensate fast enough and the stock injector are big enough
Old 06-29-2006, 06:50 AM
860 Performance's Avatar
Did you dyno it or is this driving?
Just curious.
Old 06-29-2006, 11:27 AM
94vette's Avatar
Just curious.
on the road
Old 06-30-2006, 08:49 PM
stangsteve's Avatar
wow
