spraying on forged 402???
my new 402 is in the process of being built. i was spraying 100 shot on my stock bottom end, and blew the #7 piston. so the spray has me a little worried to say the least!!
did i make the mistake of going with the aluminum 402 rather than the iron block?? please tell me ill be ok?! should the block hold a 200 shot?
motor consists of:
forged eagle crank
scat H rods
forged manley dish pistons with hellfire rings
11.x : 1 compression
absolute speed stage 2 heads
texas giant
i want to dyno a 200 shot on the car, and run around town with a 100 or 150 shot. the car is a daily driver, and i cant afford to blow up this new motor. probably only spraying 2-3 times a week if that.
im paranoid about the whole "forged" thing....someone convince me ill be ok!?
motor consists of:
forged eagle crank
scat H rods
texas giant
"most definatly" is exactly what i wanted to hear!!
ive already purchased the racetronix setup, and will be setting that up as soon as it arrives!
jeremy formato is a buddy of mine and will be doing the tuning!! so dont have to worry about that aspect!
racetronix will not be enough lol
I have their fuel pump kit with booster. I make in the 530-550 range on motor
On a 175 shot, i see a significant drop in fuel pressure. I don't think i can spray anymore than that...
It's on to new, bigger and better things.. like a dedicated system.
Race your car!
With the setup you are talking about the racetronix probably won't be enough.
If you are looking to spray more then a 100, I'd look at a dedicated setup. You could always fill that tank with good fuel too, to help prevent detonation.. a little added safety. You don't have to have a dedicated to be safe... just with a single racetronix pump and a 402, you will be pushing the envelope. A dual racetronix setup would probably be plenty if the dedicated isn't something you want to do
thanks for the info on the fuel. ill def. look into my options.
i was more interested in knowing if the internals and the aluminum block will hold up under such a big shot??
Robert
Robert
Race your car!
I"m sure the internals will be more then fine, I know of people that have been spraying 250+ on alum blocks for a LONG time, block has never been the cause of a failure.
