My new kit, your thoughts please
A Newbie to nitrous.
I'm trying to get the best and safest kit I can assemble.
What I have, and have on order:
- 500+rwhp N/A 412ci LS2 M6, in a Full weight(3800lb) WS6 Formula
- Nitrous Daves Wet plate kit, single stage (purge, blow down, heater, blanket the works).
- Timing tuner
- Wideband Commander
The question is, has anyone tried running the Timing Tuner and Wideband Commander together. I want to use the WBC for rpm, TPS position activation. The TTuner will be to retard the spark when the nitrous is activated, no program change will be required to go from N/A to spray. I will also use the WBC to shut down the system if it goes lean.
Thanks in advance for your thoughts.
Rampant
- Timing tuner
Rampant
