Nothing coming out of the purge but noise
The bottle has 5 pounds still but when I hit the purge it sounds normal and it sprays but you cant see anything at all, bottle press 950 to 1000 so is fine, but somebody told me sometimes thats normal transparent N2O coming out of there but the first time I filled up the bottle until the last pound I saw the white cloud come out.. what can be that?
Tenured Member
You might also have air in the bottle. Some places that fill bottles will run their big ones dry. There is usually about 10 lbs of Sulfer that is at the end. This is for the saftey issue to keep kids from huffing it. Well if you get sulfer you wont get the cloud plus when they pump it in with the machine they are also pumping in air. We do the Heat/Freeze method and let the path of least resistance take its course without any air getting into the system
You were correct thank you, I opened it and it took only half a min to empty, so that was the last part only air, the place said they put 7 pounds NEVER going back to that place again.
