Where do the jets go on a NX MAF kit?
Re: Where do the jets go on a NX MAF kit?
there are fittings that are attached to the MAF housing...take the -3 an line off and you will see a slightly larger hole than a normal fitting. they go in there. Should make a nice angled cone with the jet installed to seal against the female fitting. I dont really think it will fit anywhere else. Make sure though...if somehow get it in the wrong spot you will likely have fuel and nitrous leaks.
