Trick Flow heads and plugs?
Im building a 402 with Trick Flow heads, the spark plug stickie doesnt have TFS heads. Ill be running a 250 shot so ill need a colder plug, dont know if 1 or 2 stepd colder. What plug will I need? Tapered or gasket seat?
its better to be conservative until you reach the correct heat range.
i usualy gap them at .020
I take it that you have the trick flow heads? i guess 3 steps colder would be a starting point since its higher compression and a shot. Iv had better luck with the Autolight plugs then the NGK's with it idling and not fouling. Any idea of a part number?
I looked up the part numbers you gave me and have noticed that the plugs arnt a resistor plug. Do we need a resistor plug to keep electronics from being damaged.
