Help on wiring a Digital MSD w/ HSW Interface
Old 04-16-2008, 11:46 PM
ws6formula98's Avatar
Default Help on wiring a Digital MSD w/ HSW Interface
I need a wire diagram on how to wire my Interface(dry shot) and my MSD window switch with the relay and WOT switch... i had it and work without the msd, but now im adding the msd and i cant fiagure it out. i try the wire diagram from HSW and its not activating on the nitrous or the interface...its driving me crazy!!! please help
Old 04-17-2008, 12:18 AM
Matt@HSW's Avatar
Yellow wire on the MSD should go to the Blue wire on the Interface. The Brown wire on the Interface will be hooked up to pin # 85 on the N2O relay (there is a diagram at the end of the Interface Install manual). On the Interface Trigger +/- will be set to "-" and Trigger Power will need to be set to "on". If your MSD window switch is not activating the Interface won't be triggered.
Matt
Old 04-17-2008, 07:33 PM
but the interface wiring doesnt have a diagram on how to hook the WOT switch..
hads anyone wired a msd to the interface? i know of a guy that did but i cant find him.
Its a z28 from Az with the same kit, just it was a wet kit..
Old 04-18-2008, 04:03 PM
Matt@HSW's Avatar
The WOT switch can go inline on the wire from the arming switch to pin # 86 on the nitrous relay.
Matt
Old 04-18-2008, 11:38 PM
sorry but wiring is not my thing.. can you draw out a diagram with the wot switch(two wire), msd, relay, and interface?
