ATTN: MicroEDGE users...
Old 09-13-2008, 09:47 PM
  #41
bad6as's Avatar
mine works. i was comparing the n20 noid click to the purg noid click. not sure why the purg is so loud compared to the n20 noid.
but yes my rpm pulse is set at 2 and sensistitivy is at med
Old 09-13-2008, 11:42 PM
  #42
jmill96Z's Avatar
Glad to see you got it worked out.
Old 09-13-2008, 11:43 PM
  #43
bad6as's Avatar
i guess i could tell it to add fuel and see if the motor bogs. right?
Old 09-14-2008, 07:11 PM
  #44
SuperSlow02's Avatar
On your guys trigger values, how much of a drop does it take before the Edge drops back to standby, Mine is set to 4.45 while max is 4.50v. But when I start to let off the throttle it will not go back to standby till 3.85ish. Now granted this is only like 1/4in of pedal travel, but still has me wondering?
Old 09-14-2008, 07:17 PM
  #45
bad6as's Avatar
so wot your at 4.70? then subtract .25 and thats how you get your 4.45 as your trigger
thats how i did mine to. and if you roll in to it some times it triggers around 4.45. then around 4.25 it turns it off.
i raised mine up a tad i think 4.50 or 4.55
Old 09-14-2008, 07:51 PM
  #46
the instructions said to only subtract if your using Fly by wire. Mines cable driven, So I just used the value given at WOT which was 4.50, but with trigger 1 set at 4.50, it would not trigger, but when I lowered it .05, It would trigger, my problem is it will not return to standby till 3.85ish
Old 09-14-2008, 07:53 PM
  #47
bad6as's Avatar
i didnt see the fly by wire part. hsw said that the cut off is pre set
Old 09-14-2008, 08:13 PM
  #48
Ah, guess I overlooked that, I dont think the difference is enough to matter.
Old 09-14-2008, 08:18 PM
  #49
bad6as's Avatar
overlooked what?
Old 09-14-2008, 08:21 PM
  #50
the shut off being preset. In the manual it indicate that trigger 1 is the on and trigger 2 is the off. Yet in the walk through it seems like trigger 2 controls the 2nd stage...
Old 09-15-2008, 04:03 PM
  #51
bad6as's Avatar
its gotta be a typo. i was told trigger 1 is for stahe one on. trigger 2 is for stage 2 on. stage 1 and stage 2 are pre set to turn off
Old 09-15-2008, 05:32 PM
  #52
thats what im figuring. Trigger 2 is deffinently stage 2 on. didnt know the preset off was such a gap
Old 09-15-2008, 09:21 PM
  #53
and here it is....
Old 09-15-2008, 09:33 PM
  #54
jmill96Z's Avatar
Looks good. Where are you permanently mounting it?
Old 09-15-2008, 09:46 PM
  #55
bouncing around in my glove box
Old 09-16-2008, 09:44 AM
  #56
Nick@HSW's Avatar
and here it is....
Purty
Old 09-16-2008, 10:33 AM
  #57
jmill96Z's Avatar
I'll throw some pics of mine up here in a day or 2. Mines mounted on the front of the console. Actually a perfect fit.
Old 09-16-2008, 12:06 PM
  #58
hmmm, might have to steal that idea from you
Old 09-16-2008, 03:23 PM
  #59
bad6as's Avatar
ill get a pic of mine
Old 09-16-2008, 03:32 PM
  #60
bad6as's Avatar
center console pops off very easy, uses velcrow to hold it there. and also a pice to hold it down on the radio when its covered
